TwinTurbo.NET: Nissan 300ZX forum - Somewhere? Anywhere? Nowhere.....
FrozTTy
on February 11, 2015 at 1:42 PM
Installation instructions are some where on the box gentlemen.
posted by NUTTZ(EPTmotorsports)
on February 11, 2015 at 11:50 AM
What is this magical box you have?
Go read O.P. above, NGK's are installed dry in the factory.
Maybe your Champion spark plug box says use anti-seize...? Ha
Anti-seize not recommended by NGK (?)
Gromit
20:13:12 02/09/15
Re: Anti-seize not recommended by NGK (?)
ttz'in (norcal)
03:49:05 02/10/15
I know almost everyone will say to use it
FrozTTy
07:33:25 02/10/15
FWIW - I use it on the reinstalls but I've yet to run
jzack
19:20:15 02/10/15
I have stripped plugs when removing
-Grimm-
19:29:30 02/10/15
Yep - that's why I use it. Mainly I'm helping the next
jzack
18:19:38 02/11/15
Note that most plugs are not tightened to torque
-Grimm-
19:30:59 02/10/15
True but seems with this car..
Gromit
20:16:49 02/10/15
11:50:00 02/11/15
Somewhere? Anywhere? Nowhere..... -
FrozTTy
13:42:17 02/11/15
you are absolutely correct, it says nothing about anti sieze
09:27:36 02/12/15
that's like saying you should air your tire to..
Gromit
18:52:44 02/13/15
There is a max psi though, would you go over that? (n/m)
16:19:12 02/14/15
no
Gromit
20:21:47 02/14/15
