TwinTurbo.NET: Nissan 300ZX forum - Opinions on Valves Sticking
Subject Opinions on Valves Sticking
Posted by -Grimm- on February 11, 2015 at 12:39 PM
  This message has been viewed 374 times.
Message Moreso trying to see if I have any other options before pulling the head... again
History: I rebuilt the Z engine, had it bored + 0.5mm, heads decked and completely rebuilt/reground.
After initial assembly, I was having issues running on 4 cylinders. Narrowed it down to bad valves (Exhaust valves sticking open) see HERE
Got it back together 6 months ago, was running OK. Ran an ECU power balance test and... cylinder 6 still not contributing. So I disconnected the injector and drove it into my garage. Been working on other projects for the last 4 months but finally got back around to the Z.
After tearing it down again... Leakdown test shows cylinder 6 intake valve is leaking. See below
Left valve not closing fully (Picture taken with cam and lifters removed)
Valves open (Reinstalled cam and lifters)
I don't see anything obvious on the valve stem that would cause it to hang up, using the bore-scope again the gap seems even all around suggesting the valve isn't bent (Or if it is, very slightly)
Anything else I should try before removing the head, and finding a new machine shop to fix the old machine shops (two round of) mistakes?
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Est. 400 HP)
1990 300ZX TT 5 Sp (Est. 600 HP)
2004 G35 Sport 6MT (DD)
