TwinTurbo.NET: Nissan 300ZX forum - first make sure your engine harness is plugged in correctly
Subject first make sure your engine harness is plugged in correctly
Posted by NUTTZ(EPTmotorsports) on February 11, 2015 at 12:08 PM
  This message has been viewed 198 times.
In Reply To Car jerking under load.. the symptoms and codes posted by nonstopna on February 08, 2015 at 02:18 AM
Message I've seen coill packs 4,6, and 5 with the O2's plugs in em, the #6 injector mixed up with the acc plug, and check the tps sensor too.
If the harness checks out than check the fuel pressure, it should be around 45 with key on car off and around 38 with the car running.
If the fuel pressure checks out pull the plugs, and while the plugs are out do a compression test.
