TwinTurbo.NET: Nissan 300ZX forum - Installation instructions are some where on the box gentlemen.
NUTTZ(EPTmotorsports)
on February 11, 2015 at 11:50 AM
True but seems with this car..
posted by Gromit
on February 10, 2015 at 08:16 PM
Isn't anti-sieze used when two different types of metal are involved? An example is screwing a steel bolt in an aluminum head because they cool at different rates so the metals may fuse together after so long or so many heat cycles.
Anti-seize not recommended by NGK (?)
Gromit
20:13:12 02/09/15
Re: Anti-seize not recommended by NGK (?)
ttz'in (norcal)
03:49:05 02/10/15
I know almost everyone will say to use it
FrozTTy
07:33:25 02/10/15
FWIW - I use it on the reinstalls but I've yet to run
jzack
19:20:15 02/10/15
I have stripped plugs when removing
-Grimm-
19:29:30 02/10/15
Yep - that's why I use it. Mainly I'm helping the next
jzack
18:19:38 02/11/15
Note that most plugs are not tightened to torque
-Grimm-
19:30:59 02/10/15
Gromit
20:16:49 02/10/15
Installation instructions are some where on the box gentlemen. -
11:50:00 02/11/15
Somewhere? Anywhere? Nowhere.....
FrozTTy
13:42:17 02/11/15
you are absolutely correct, it says nothing about anti sieze
09:27:36 02/12/15
that's like saying you should air your tire to..
Gromit
18:52:44 02/13/15
There is a max psi though, would you go over that? (n/m)
16:19:12 02/14/15
no
Gromit
20:21:47 02/14/15
