TwinTurbo.NET: Nissan 300ZX forum - Re: Cold start troubles
Subject Re: Cold start troubles
Posted by zromtech on February 07, 2015 at 1:29 PM
  This message has been viewed 227 times.
In Reply To Cold start troubles posted by jesusyi123z32 on February 04, 2015 at 07:15 PM
Message If the problem is a cold-start hesitation that goes away after driving a few blocks, it may just be the (functioning as designed) catalyst warmup system in the ECU. This is an emissions control system that retards the ignition timing under specific warm-up conditions to rapidly heat the catalytic converters up to their 'spark point'. When this system is active there is a lot of hesitation at partial throttle below 2600rpm and bucking during throttle on/off transitions.
Does the problem abruptly go away above 2600rpm or once coolant temp hits 55C (130F)?
