TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: Assuming the injectors are good, I think "O" ring.
msb1987
on January 22, 2015 at 9:40 PM
posted by jmay
on January 22, 2015 at 09:43 AM
The injector can be fine but the o-ring could be the problem. Run it for a bit and then pull the plugs on those cylinders to see if they are wet. If so then test for spark. Where you go from there depends on what you find.
Gas soaked exhaust?? (different from previous threads)
jmay
21:48:08 01/18/15
Re: Gas soaked exhaust?? (different from previous threads)
Goldchocobo
03:08:53 01/19/15
10-14 ohms (n/m)
FrozTTy
07:25:03 01/19/15
I was told that the new style injectors don't fail very
msb1987
10:24:35 01/19/15
Assuming the injectors are good, I think "O" ring. (n/m)
ttz'in (norcal)
14:46:43 01/19/15
jmay
15:58:23 01/19/15
Kvert
22:28:11 01/19/15
jmay
09:43:47 01/22/15
Re: Re: Re: Re: Assuming the injectors are good, I think "O" ring. -
msb1987
21:40:34 01/22/15
