TwinTurbo.NET: Nissan 300ZX forum - As previously mentioned my set came with gaskets
Subject As previously mentioned my set came with gaskets
Posted by SammybTT(TN) on January 22, 2015 at 12:08 PM
  This message has been viewed 249 times.
In Reply To drivers side MSP manifold doesnt fit posted by esuttar on January 21, 2015 at 10:35 PM
Message and the hardware kit. If it was me I would do exactly as Mario stated: install a nut, run it all the way down the stud until it bottoms out, use a die grinder and remove excess length, back out nut which will clean up your threads and you should be good to go. It is still a tight fit with the shorter stud.
