TwinTurbo.NET: Nissan 300ZX forum - Re: Blue smoke is burning oil
Subject Re: Blue smoke is burning oil
Posted by tian2bing on January 21, 2015 at 12:15 PM
  This message has been viewed 288 times.
In Reply To Blue smoke is burning oil posted by -Grimm- on January 21, 2015 at 12:11 PM
Message i've been running it for 20 miles and it smokes really bad
I gutted both pre-cat and cat.
the whole engine and turbos are brand new from nissan dealer so I guess these couldn't go wrong
i'll go check pcvs
:How many miles does the engine have, has it been broken in at all?
:Also... important... did you replace PCV's when you swapped your plenum?
:If it was just at initial startup I would say its from residual oil coating from assembly.
:If it is an ongoing issue I would suspect your rings weren't properly seated, turbo seals, or bad PCV's
