TwinTurbo.NET: Nissan 300ZX forum - Re: any info on width of rims?
Subject Re: any info on width of rims?
Posted by RobZ32 on January 20, 2015 at 10:12 AM
  This message has been viewed 298 times.
In Reply To any info on width of rims? posted by BeBoosted on January 20, 2015 at 09:50 AM
Message It's all a matter of having the right offset and the right tire compound.
Realistically you can fit a 10.5" wheel (with the right offset) without having to do any mayor modifications to the Z, a side from maybe a fender roll or a slight pull.
Something wider will require modification of the rear suspension or a wide body kit or using some sort of spacer (which I would not advice in your power range)
That being said, with a 10.5" you can find many options in tire compound using a size 315/30/18 that will hold the power.
Rob
It's never "DONE", just finished enough to drive :-) - BigTDogg
(MA)
