TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Assuming the injectors are good, I think "O" ring.
Subject Re: Re: Assuming the injectors are good, I think "O" ring.
Posted by Kvert on January 19, 2015 at 10:28 PM
  This message has been viewed 240 times.
In Reply To Re: Assuming the injectors are good, I think "O" ring. posted by jmay on January 19, 2015 at 03:58 PM
Message Did you pull the plugs after it ran a bit to confirm it's dumping fuel? They'd be wet if it is. Are you sure you've got spark to the cylinders in question? If you've got spark and it's wet with fuel then it an oring or injector. Pull intake and reattach fuel lines to rail. Pressurize and look for drips. Note if drip come from injector tip or around injector/fuel rail.
