TwinTurbo.NET: Nissan 300ZX forum - Re: Just pulling the fuse kills the continuity to ground.
Subject Re: Just pulling the fuse kills the continuity to ground.
Posted by Cjw3 on January 17, 2015 at 5:15 PM
  This message has been viewed 269 times.
In Reply To Just pulling the fuse kills the continuity to ground. posted by LivinTheDream on January 16, 2015 at 09:24 PM
If you look at the O2 Sensor in the middle.. B/R is on one side of the heater.. and Blk is on the other side.. Follow the Blk back to the ECU it LOOKS like it falls into pin 115.. It's hard to tell, but it also looks like 107/108/115/116 are all hooked together.. and they go to ground..
I'd have to ohm all the ECU Harness pins to tell..
Cj
