TwinTurbo.NET: Nissan 300ZX forum - I figured this much BUT question....
Subject I figured this much BUT question....
Posted by LivinTheDream on January 13, 2015 at 12:13 PM
  This message has been viewed 266 times.
In Reply To Your post is a little confusing. posted by Cjw3 on January 12, 2015 at 08:16 PM
Message The power supply lead for the vtc, wategates etc, which on my 93 is a black wire with red stripe, runs to a 10amp fuse and that is fed by what appears to be ignition switch and a controller module.
I understand the concept but with the battery unplugged and the ecu unplugged the circuit has continuity with ground. If I test from the supply side for the 10amp fuse it gives me continuity with ground. So I'm wondering if while the ignition switch is off this +lead is grounding out or something of that sort?
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
