TwinTurbo.NET: Nissan 300ZX forum - Normally its just a teaspoon or so of oil. Just enough to
Subject Normally its just a teaspoon or so of oil. Just enough to
Posted by jzack on January 10, 2015 at 10:02 AM
  This message has been viewed 292 times.
In Reply To How do I address the washed cylinder? Anything before the posted by msb1987 on January 10, 2015 at 09:47 AM
Message get the job done (seal). If worried about gas in the cyclinder (or cylinders). Just crank the engine a bit with all the spark plugs removed (and injectors disabled). That should take care of it.
I'm assuming you already know that when running the compression test that the injectors need to be disabled. Pulling the plug on the CAS keeps the ECU from firing the injectors but disabling the fuel pump is better - since a leaky injector could still be supplying some fuel if the pump pressurizes.
FWIW - A turkey baster is a handy tool to have around the shop. Good for many little jobs (ie., removing fluids, etc). Makes is pretty easy to add a small bit of oil down the spark plug hole. Just fit a piece of clear tubing to the end of the baster and then suck up a little bit of oil. Allows the hose to get much farther down the long spark plug access hole.
