TwinTurbo.NET: Nissan 300ZX forum - We're talking about 7.5mm deflection according to the fsm.
Subject We're talking about 7.5mm deflection according to the fsm.
Posted by flashstar on January 10, 2015 at 1:12 AM
  This message has been viewed 308 times.
In Reply To 2nd^ premature w/p failure due to belt being overtightened (n/m) posted by FrozTTy on January 09, 2015 at 06:50 PM
Message The fsm is incorrect, however it makes sense that the alternator belt requires the most tension. It drives the water pump and alternator- 2 accessories that are used extensively at idle.
Deflection is measured at roughly 20 lbs of force. For me, 20 lbs takes a good effort with 2 fingers. I cannot press hard enough with one finger.
The oem spec is VERY tight on the alternator belt. Are you sure you didn't get a defective water pump? Aftermarket ones are known to fail.
