TwinTurbo.NET: Nissan 300ZX forum - Do you recommend tightening them more than OEM spec?
flashstar
on January 08, 2015 at 1:27 AM
UR pulley belts need to be very tight, like 1/4"
posted by ttz'in (norcal)
on January 07, 2015 at 01:11 PM
The FSM recommends something like 7-8mm deflection for the alternator belt (worn). This is just a bit more than 1/4".
Unorthodox crank pulley makes belts squeal badly
Devonz32
01:48:32 01/06/15
Since the belts are new, they are probably loose.
The Sixth
11:39:46 01/06/15
As noted above do, here are specs on thension>>
ZUL8TR
12:15:37 01/06/15
Re: Unorthodox crank pulley makes belts squeal badly
kbilow
18:17:26 01/06/15
kbilow
18:17:34 01/06/15
Mine does the same but you can't really hear it over the
SammybTT(TN)
21:05:33 01/06/15
Clean your pulleys and try Gates racing blue belts
flashstar
10:36:53 01/07/15
ttz'in (norcal)
13:11:58 01/07/15
Do you recommend tightening them more than OEM spec? -
flashstar
01:27:42 01/08/15
Yes, OEM specs seem to be a bit loose for the UR
ttz'in (norcal)
02:30:14 01/08/15
My new Gates racing alternator belt loosened in just 10
flashstar
01:17:32 01/10/15
The pulley groove is too slick. Maybe this..
shaggee
14:07:29 01/07/15
Interesting..Worth a try if all else fails. (n/m)
ttz'in (norcal)
02:34:07 01/08/15
Re: Interesting..Worth a try if all else fails.
kbilow
12:02:59 01/09/15
2nd^ premature w/p failure due to belt being overtightened (n/m)
FrozTTy
18:50:10 01/09/15
We're talking about 7.5mm deflection according to the fsm.
flashstar
01:12:20 01/10/15
*May be incorrect (n/m)
flashstar
01:13:02 01/10/15
i got my 120k kit from kyle at IPP
FrozTTy
09:47:02 01/11/15
