TwinTurbo.NET: Nissan 300ZX forum - Re: Not in my experience
Subject Re: Not in my experience
Posted by kbilow on January 06, 2015 at 6:29 PM
  This message has been viewed 265 times.
In Reply To Not in my experience posted by -Grimm- on January 02, 2015 at 06:05 PM
Message Haven't pulled the heads but I think I found the problem there was quite a bit of oil in my plenum from failed pcv valves and a lot of burned on oil/carbon on my intake valves been cleaning the with atf (seems to be working well) but I found the cylinders with low compression each had 1 intake valve that are leaking the aft slowly not allowing it to clean the carbon off I will just keep working at it probably do a leak down this weekend to get an idea of exhsust valve and ring condition and post findings
