TwinTurbo.NET: Nissan 300ZX forum - Yes at TDC for #1 at compression stroke all the dots >>
ZUL8TR
on January 06, 2015 at 12:20 PM
Ok, thanks. I will check the oil and coolant for...
posted by Z-line
on January 04, 2015 at 05:41 PM
on the cam gears and crank gear should line up with the marks on the backing plates. Also count teeth between marks for all positions as in the manual.
ZUL8TR in Orlando,FL
compression test results on a TT engine
Z-line
01:42:19 01/04/15
You should run a Leakdown test
Stanky
02:06:20 01/04/15
Z-line
17:41:01 01/04/15
Do you own a coolant pressure tester?
Stanky
20:38:34 01/04/15
I will go ahead and rent one and report back, Thx (n/m)
Z-line
21:06:54 01/04/15
The TB marks will not be aligned. You will have to align
SammybTT(TN)
13:12:30 01/05/15
Yes at TDC for #1 at compression stroke all the dots >> -
ZUL8TR
12:20:39 01/06/15
do what stanky said
FrozTTy
11:08:57 01/04/15
good advice above
SammybTT(TN)
13:32:29 01/05/15
