TwinTurbo.NET: Nissan 300ZX forum - Re: So what would your next move be? Thanks for the help.
MaxxAction
on January 06, 2015 at 11:53 AM
So what would your next move be? Thanks for the help. (n/m)
posted by msb1987
on January 06, 2015 at 11:40 AM
Turn the car on, let it build fuel pressure, and then pull the vacuum reference hose on the FPR and check it. If that is the problem, it will be dripping fuel out of the vacuum hose.
How can my car run run with all the injector connectors
msb1987
18:43:40 01/05/15
Could a failed FPR in the closed position cause enough...
msb1987
22:21:37 01/05/15
I saw your earlier post. From what you wrote of your
doug8867
22:41:30 01/05/15
Thanks for the reply and that is what I was thinking when
msb1987
22:54:48 01/05/15
Does it 'run', or is it run-on
-Grimm-
01:03:48 01/06/15
Honestly I could not tell you. I was so shocked when it
msb1987
07:15:24 01/06/15
Re: How can my car run run with all the injector connectors
MaxxAction
10:11:35 01/06/15
No change or upgrade. Maybe I'm wrong but isn't very..
msb1987
10:29:36 01/06/15
Re: No change or upgrade. Maybe I'm wrong but isn't very..
MaxxAction
11:06:13 01/06/15
msb1987
11:40:23 01/06/15
Re: So what would your next move be? Thanks for the help. -
MaxxAction
11:53:50 01/06/15
Car on, means key turned to on or...
msb1987
13:19:47 01/06/15
So apparently my car achieved the holy grail of
msb1987
14:01:52 01/06/15
Solved or at least part of it...
msb1987
19:27:31 01/06/15
http://z32.wikispaces.com/Fuel+Injector+Replacement (n/m)
ThisIsSparTTa
12:00:29 01/07/15
Prepare for a lot of work
-Grimm-
12:40:55 01/07/15
why is it in the plenum though???? anyone
LivinTheDream
09:56:50 01/08/15
^Yeah
-Grimm-
11:39:51 01/08/15
