TwinTurbo.NET: Nissan 300ZX forum - Yes, noid light is quickest way to check.
Subject Yes, noid light is quickest way to check.
Posted by ttz'in (norcal) on January 05, 2015 at 3:10 AM
  This message has been viewed 323 times.
In Reply To Re: Is ECU sending ground signal to #1 ? posted by msb1987 on January 04, 2015 at 10:11 PM
Message I had continuity in ground wire from injector connector to ECU connector, but no signal.
Ran jumper wire from #3 to #2 injector connector ground wire with small alligator clips. If your problem cylinder is #1, jumper wire to #2, or 3 is probably easiest.
Attach FI connectors, start engine and in 10 seconds you'll know. If idle is normal, #1 isn't getting a ground signal. To verify remove alligator clip and notice if idle goes back to miss-fire condition.
