TwinTurbo.NET: Nissan 300ZX forum - change oil now
Subject change oil now
Posted by LivinTheDream on January 05, 2015 at 12:34 AM
  This message has been viewed 313 times.
In Reply To Added data after ECU testing...(long) posted by msb1987 on January 04, 2015 at 02:05 PM
Message with that injector dumping so much fuel you could very well have contaminated oil and you'll be worrying about alot more than a dead cylinder.
Seems like the injector is stuck open. Leave the problematic injector disconnected as well as all the others. Pull the spark plug to that cylinder and roll the engine a few times to see if fuel is still spraying into the chamber. If so this means that the injector is open and fuel pressure alone is free flowing gas into the engine.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
