TwinTurbo.NET: Nissan 300ZX forum - Re: Is ECU sending ground signal to #1 ?
msb1987
on January 04, 2015 at 10:11 PM
posted by ttz'in (norcal)
on January 04, 2015 at 06:54 PM
Thanks for the reply. How do I test for this? I'm sure I read it somewhere but I've been searching and reading so much it is like I'm caught in a loop. Is that the noid light thing I have been reading about?
Code 51 advice
msb1987
13:08:56 01/03/15
Re: Code 51 advice
msb1987
13:18:38 01/03/15
Leave injectors connected when testing continuity through...
-Grimm-
01:26:33 01/04/15
Added data after ECU testing...(long)
msb1987
14:05:18 01/04/15
ttz'in (norcal)
18:54:59 01/04/15
Re: Is ECU sending ground signal to #1 ? -
msb1987
22:11:14 01/04/15
Yes, noid light is quickest way to check.
ttz'in (norcal)
03:10:30 01/05/15
Re: Yes, noid light is quickest way to check.
msb1987
18:05:29 01/05/15
Code 51 is more of an open ended code
-Grimm-
01:06:00 01/06/15
Re: Code 51 is more of an open ended code
msb1987
09:12:16 01/06/15
Compression testing
-Grimm-
10:57:19 01/06/15
change oil now
LivinTheDream
00:34:13 01/05/15
help!!!!
msb1987
18:40:47 01/05/15
Should I do the same test but with the coil packs pulled? (n/m)
msb1987
22:55:58 01/05/15
