TwinTurbo.NET: Nissan 300ZX forum - Do you own a coolant pressure tester?
Subject Do you own a coolant pressure tester?
Posted by Stanky on January 04, 2015 at 8:38 PM
  This message has been viewed 434 times.
In Reply To Ok, thanks. I will check the oil and coolant for... posted by Z-line on January 04, 2015 at 05:41 PM
Message If not you can usually rent them any some Auto parts store for cheap. Remove spark plugs on that bank, remove radiator cap, and pressurize the system. Look for any sign of pressure dropping. If your HeadGasket is on it's way out, you should see coolant building up in the cylinder(s).
Was any timing components changed recently? I would say it's highly unlikely that all 3 cylinders on that one bank would have worn rigs for example. Just start with the basic inspections, post results, and we'll go from there.
