TwinTurbo.NET: Nissan 300ZX forum - I would do a power balance e test to see if you can
Subject I would do a power balance e test to see if you can
Posted by SammybTT(TN) on December 29, 2014 at 10:59 PM
  This message has been viewed 244 times.
In Reply To Checked the following and still no luck: posted by LivinTheDream on December 29, 2014 at 08:36 PM
Message Determine which cylinder is acting up. Basically this is removing the coil wire one at a time while the engine is running. You should notice a change in the engine operation if that cylinder is functioning properly , if no change then you have located the suspect cylinder. Good luck and let us know what you find.
