TwinTurbo.NET: Nissan 300ZX forum - High gear slippage is the easiest way to check for...
Subject High gear slippage is the easiest way to check for...
Posted by -Grimm- on December 29, 2014 at 5:51 PM
  This message has been viewed 213 times.
In Reply To 25k with spirited driving is on the low side of normal but posted by doug8867 on December 29, 2014 at 03:25 PM
Message clutch life. In 4th gear at low RPM, give it full throttle. If the clutch is severely worn the torque will overcome the clutch and you will slip at some point during acceleration.
That being said, I agree with your statement for the OP, clutch life depends on the driver. Launches can kill a clutch quickly, where daily smooth driving is easy on the friction disc.
If you have babied your clutch, and you broke it in when you installed it, maybe there is another issue at play;
-Leaking oil onto the friction disc?
-Slave cylinder binding, not fully releasing the fork?
-Clutch fork/pivot ball not properly seated?
-Improper clutch pedal adjustment?
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Est. 400 HP)
1990 300ZX TT 5 Sp (Est. 600 HP)
2004 G35 Sport 6MT (DD)
