TwinTurbo.NET: Nissan 300ZX forum - turn the idle screw all the way in, unplug the AAC,
Subject turn the idle screw all the way in, unplug the AAC,
Posted by surfer31337 on December 28, 2014 at 10:46 PM
  This message has been viewed 204 times.
In Reply To Idle issue continue.. posted by starscream714 on December 27, 2014 at 02:32 PM
Message set the ignition timing using a timing light (the ECU assumes you did that, so it says 15 but that doesn't mean it's really 15), check for vacuum leaks by pressure testing the intake plumbing with compressed air
question, is it a smooth, steady idle? or does it fluctuate?
question, is the idle speed any different when cold vs warm? normally, it should start at 1300 and drop down to 700.
report back the results
ok now someone plz answer my clutch question before my car becomes undrivable, lol
