TwinTurbo.NET: Nissan 300ZX forum - Your data links look OK. My guess is too much idle air
Subject Your data links look OK. My guess is too much idle air
Posted by Gordo 93TT Daytona on December 28, 2014 at 4:15 PM
  This message has been viewed 200 times.
In Reply To Idle issue continue.. posted by starscream714 on December 27, 2014 at 02:32 PM
Message Throttle plates seating OK?
Using needle nose vice grips squeeze close the air coming from/into the plenum from the IACV and Air Regulators.
Air leaks around plenum gasket?
Injector O rings sealing tight?
Check all of the fittings on plenum. Have you deleted the water hoses w/o plugging ports?
Loose or missing caps on ports?
Keep checking listening for air leak / hissing / etc.
_________________________________________________
