TwinTurbo.NET: Nissan 300ZX forum - Figured it out!
Figured it out!
Z32CheekiBreeki
on December 28, 2014 at 2:01 PM
Need help with vacuum routing on an NA
posted by Z32CheekiBreeki
on December 28, 2014 at 12:47 PM
Did a little more poking around and found that it connects the egr solenoid to the egr valve! Now all I gotta do is route some hosing there, which looks like a Bitch to do btw
Other questions still stand
Z32CheekiBreeki
12:47:53 12/28/14
Figured it out! -
Z32CheekiBreeki
14:01:14 12/28/14
FWIW: With the battery out that EGR vacuum nose isn't too
jzack
10:00:51 12/29/14
1/4" = 6.35mm so it will not be as tight a fit as 6mm.>>
ZUL8TR
16:54:37 12/28/14
Got all the hoses done
Z32CheekiBreeki
19:52:02 12/28/14
Spray some brake cleaner in that area, and listen
ttz'in (norcal)
22:48:03 12/28/14
Put a vacuum gage on the engine and run it and read the >>
ZUL8TR
04:14:38 12/30/14
Well sprayed lots of carb cleaner in the area
Z32CheekiBreeki
14:52:10 12/30/14
Vac gage might reveal issues you don't even notice>>
ZUL8TR
04:43:26 12/31/14
