TwinTurbo.NET: Nissan 300ZX forum - Typical polyurethane bushings can be torqued down in the air
Subject Typical polyurethane bushings can be torqued down in the air
Posted by flashstar on December 26, 2014 at 5:28 PM
  This message has been viewed 252 times.
In Reply To Those new ES bushings could be binding posted by BarryGZX on December 25, 2014 at 07:42 PM
Message It's just important to make sure the polyurethane ends aren't getting pinched in the mounting brackets. You want the crush tubes to be the only things contacting the brackets.
Typical rubber bushings need to be torqued down while your car is on the ground because the rubber twists. Polyurethane bushings rotate around the crush tubes.
