TwinTurbo.NET: Nissan 300ZX forum - Think so. Inner sleeve was the only thing longer...
evan_aggie
on December 26, 2014 at 2:23 PM
If I remember correctly.
posted by BarryGZX
on December 26, 2014 at 01:07 PM
The black alloy itself measured out to be the same size. However, it appeared the inner metal sleeve was a little longer on one end, and that was the end I attached to the engine side.
Post Z1 FUCA Install - Ride Height Problem(s)
evan_aggie
17:15:56 12/25/14
Those new ES bushings could be binding
BarryGZX
19:42:27 12/25/14
lower control arms, trods, & upper arms all torq'd weighted? (n/m)
evan_aggie
20:24:53 12/25/14
yep (n/m)
BarryGZX
23:42:24 12/25/14
BTW: what exactly is bushing bind (ES bushings) ? (n/m)
evan_aggie
10:04:47 12/26/14
If tq'd in the air, they twist when you lower the car. (n/m)
Ted (92TT)
11:58:36 12/26/14
I noticed this: one of the Z1 bushings looks angled now...
evan_aggie
12:07:56 12/26/14
BarryGZX
13:07:17 12/26/14
Think so. Inner sleeve was the only thing longer... -
evan_aggie
14:23:09 12/26/14
Typical polyurethane bushings can be torqued down in the air
flashstar
17:28:41 12/26/14
What about his lower control arms? (n/m)
BarryGZX
21:35:39 12/26/14
this is why. ..if you trust the site..
evan_aggie
07:48:38 12/27/14
I think lower arm bushing is a little different (n/m)
BarryGZX
11:36:46 12/28/14
I checked my urethane lowers- the crush tubes aren't bonded
flashstar
01:16:31 12/29/14
Ugh, still got problems
evan_aggie
16:19:46 12/26/14
Spring fully seated on the high side? (n/m)
Ted (92TT)
21:57:38 12/26/14
yup. same exact length too..15" on both sides
evan_aggie
07:44:53 12/27/14
Are you taking your measurements from
BarryGZX
11:40:11 12/28/14
Yes/No. 15" no. That is total length hanging, but I did
evan_aggie
15:31:43 12/28/14
