TwinTurbo.NET: Nissan 300ZX forum - Re: Re: specifics
Subject Re: Re: specifics
Posted by Duke51 on December 24, 2014 at 1:54 AM
  This message has been viewed 225 times.
In Reply To Re: specifics posted by Goldchocobo on December 23, 2014 at 10:51 PM
Message I know the starter relay works, but I don't know if its 100% I bench tested it using a smaller 12 volt battery and it works as it should, I have a back up one as well, but I'll do a swap and see what the results are.
Because of how I'm bypassing the inhib to get it to start and that when I bridge the plug (connect both sides with a wir to act as if the inhib is sending a good signal) it doesn't start, so I am thinking I have a possible short?
The second plug that comes off of the inhib switch has five wires and connects in the engine compartment on top on the passenger side wheel well, I am also wondering if my problem may be here. I'll test both and let you know what I find out. I'm thinking it my be a bad wire in the harness that crosses along the front of the engine bay.
