TwinTurbo.NET: Nissan 300ZX forum - Re: Starter Woes
Subject Re: Starter Woes
Posted by Retro-Cow on December 23, 2014 at 12:21 PM
  This message has been viewed 410 times.
In Reply To Starter Woes posted by Retro-Cow on December 21, 2014 at 07:37 PM
Message Okay a little bit of an update.
I tested the B/Y wire (which is connected to the B/W wire as per the starter relay bypass) and it is getting just a tad under 12V when the key is at start.
I also tested the starter itself. The wire that attaches via plastic connector on the starter shows 0 volts when the key is turned. (I tested it where the wire meets the starter solenoid body.)
I also disconnected the aforementioned connector and tested the harness end of the connector (not sure if this is supposed to have voltage) but still 0V.
Now if I am not mistaken, the wire that I tested should be the same B/Y from the driver's side fender well... So somewhere in between there and the starter it's losing continuity right?
