TwinTurbo.NET: Nissan 300ZX forum - Continuity testing of relays/ switches, etc will not >>
Subject Continuity testing of relays/ switches, etc will not >>
Posted by ZUL8TR on December 23, 2014 at 5:06 AM
  This message has been viewed 268 times.
In Reply To 1990 300zx will not start under normal conditions posted by Duke51 on December 23, 2014 at 02:04 AM
Message always give a positive result because there is not the actual amperage flow in the test that the component receives. Relays could have burnt contacts that give continuity but can't pass the current. I had that issue with the start circuit on my Z. Relay tested OK but had to replace it to get it to start. With all start issues I first do a complete starter circuit bypass by jumping from the battery direct to the bendix solenoid on the starter. If it starts the starter is OK and issues are upstream of that like relays, switches, etc. If it doesn't start the starter bendix is the issue or wire windings and I pull the starter for further testing on the bench. BTW a starter bench test will not always catch a bad/lazy starter. Been there.
In your case it sounds like the inhib switch.
ZUL8TR in Orlando,FL
