TwinTurbo.NET: Nissan 300ZX forum - Yes, ground clipped to a good (known) ground
Subject Yes, ground clipped to a good (known) ground
Posted by -Grimm- on December 22, 2014 at 3:43 PM
  This message has been viewed 405 times.
In Reply To Re: Yes, ignition switch turned posted by Retro-Cow on December 22, 2014 at 03:13 PM
Message Test with some +12V wire to make sure.
If you bypassed the starter relay then you also bypassed your inhibitor and security.
If you can crank over manually as you stated (jumping the post on the starter), and the multimeter shows no voltage to the B/W wire then you may be having issues in your ignition switch.
Any work in the steering column recently?
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Est. 400 HP)
1990 300ZX TT 5 Sp (Est. 600 HP)
2004 G35 Sport 6MT (DD)
