TwinTurbo.NET: Nissan 300ZX forum - Control Arm Install - OEM Bracket Isolation Foam?
Subject Control Arm Install - OEM Bracket Isolation Foam?
Posted by evan_aggie on December 17, 2014 at 2:30 PM
  This message has been viewed 388 times.
Message I noticed when I removed my OEM control arm bracket that some old foam came off with it where the bottom two studs. I was just curious if there was any need or if it'd be recommended to add some thin foam around those studs?
I have some closed cell foam that is very thin that I could put there or some rubber b-quiet sound mat as well.
Here is a pic for reference. The part that I think had some foam on it is on the outside portion of each of these brackets. This is NOT my photo, but just something random online.
