TwinTurbo.NET: Nissan 300ZX forum - Re: Sounds like the linkage arm under the car.
Subject Re: Sounds like the linkage arm under the car.
Posted by Goldchocobo on December 06, 2014 at 1:30 PM
  This message has been viewed 275 times.
In Reply To Sounds like the linkage arm under the car. posted by Whip on December 05, 2014 at 08:41 PM
Message I'm pretty sure it's the issue. While I was under there, I noticed a saggy rear transmission mount, and a completely blown center bearing, so I'm dealing with those first.
Interesting sidenote: I have removed the center bearing from the drive shaft, and while the rubber support has completely 100% separated from the bearing, the bearing itself had zero play and was in good working order. I have know idea how long the car was driven like this (a couple thousand K at most), but I found it weird that all that play and vibration hadn't completely destroyed the bearing itself.
