TwinTurbo.NET: Nissan 300ZX forum - Core size isn't everything.
Subject Core size isn't everything.
Posted by Frldy_Z on December 02, 2014 at 8:14 AM
  This message has been viewed 311 times.
In Reply To Re: Z1 BA SMIC vs Ash Spec ? posted by mizzuh on December 02, 2014 at 01:03 AM
Message The end caps have a lot to do with flow and cooling properties on IC's. If the end caps are not designed right then core size does not matter much. Poor design makes the hot air travel across the core uneven. The bigger the core the more you have to compensate on the end caps because there is a limited amount of room in the z. Need flow data, pressure drop data, cooling data from both to decide which one is better. I am guessing that ash's are better. More R&D has gone into them, plus Ash has 3 different versions. Ash claims only a 1 psi drop which is a bold statement! Someone with a flow bench want to test them?
