TwinTurbo.NET: Nissan 300ZX forum - 2nd, ASAP
Subject 2nd, ASAP
Posted by ttz'in (NorCal) on December 01, 2014 at 7:04 AM
  This message has been viewed 367 times.
In Reply To Ex Cam crack posted by 95TTurboZX on November 30, 2014 at 05:53 PM
Message Looks of those four bolts, pulley may slide off snout ?
Pulley only:
PB Blast soak the pulley bolts and center area where snout would be.
Lock or soft tip clamp all four pulleys to prevent rotation. Release T-belt tension via the tensioner slowly, just need wiggle (belt off) room at pulley.
Using puller carefully replace pulley,certain of flush fit before fitting belt.
Re-set Tension.
