TwinTurbo.NET: Nissan 300ZX forum - which cylinders are glazed?
Subject which cylinders are glazed?
Posted by Frldy_Z on November 29, 2014 at 10:27 AM
  This message has been viewed 277 times.
In Reply To Update to burning oil issue posted by Barthur on November 28, 2014 at 09:27 AM
Message if all are glazed I would suspect the machine work done by the shop. Need to check piston to cylinder wall gap. What they claim and what is actually there could reflect the problem. What pistons are you running? Forged pistons need a slightly bigger gap for the expansion rate of the silicon in the piston. Different piston composition and boost levels need to be dialed in properly for piston to cylinder wall gap. Most regular machine shops don't get it right for the VG block.
