TwinTurbo.NET: Nissan 300ZX forum - Much safer than dremel and tweezers...
Subject Much safer than dremel and tweezers...
Posted by Ted (92TT) on November 25, 2014 at 7:28 PM
  This message has been viewed 961 times.
In Reply To Chipping the ECU posted by Cjw3 on November 23, 2014 at 12:19 PM
Message $10 Desoldering Iron
I would also recommend getting some conformal coating and reseal the circuit board to protect it from corrosion. Lacquer thinner works well to remove the coating and might be safer for the ECU than brake cleaner depending on what chemicals are in it.
Conformal Coating
The ECU is a multi-layer circuit board. Keep this in mind when soldering or desoldering, as it is possible to leave an open circuit if the solder does not flow through completely.
