TwinTurbo.NET: Nissan 300ZX forum - ive done it with a TT
Subject ive done it with a TT
Posted by LivinTheDream on November 24, 2014 at 5:12 PM
  This message has been viewed 285 times.
In Reply To "Head Job!" posted by MERKINSTYLE on November 23, 2014 at 08:23 AM
Message Pull the head with exhaust manis and turbos attached but down pipes removed. Install will have to be the same BUT it is HEAVY and you have to be careful not to mess up the head gasket. If your using studs you cannot slide the head down in the studs. You have to gently rest the head and turbo assembly only the block/head gasket and someone support it while bolts are installed. It will want to tilt/rock/shift and this can damage the head gasket. I did this by myself after messing up 2pairs of head gaskets. Make sure who ever is helping you if you have a helper is serious and not messing around or they will cost you head gaskets.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
