TwinTurbo.NET: Nissan 300ZX forum - Either way you decide should include the 12 volt
Subject Either way you decide should include the 12 volt
Posted by ttz'in (NorCal) on November 23, 2014 at 4:31 AM
  This message has been viewed 355 times.
In Reply To 92 300ZX Twin Turbo injector solution posted by Pontisteve on November 23, 2014 at 12:00 AM
Message switched modification.
[ http://twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=1109134&forum=technical&dtSearch=1 ]
Early style injectors are "pintle-style" design.
There is a rod (pintle) that is pulled up by an electromagnet to allow fuel to flow out.
Pintle-Style had a weakness in high flow situations called "floating". Meaning they could stay partially open when they should be closed, or vice versa due to the vertical design of the rod, or "pintle".
New Style are "Disc-Style".
Vertical pintle design was replaced by a rotating disc,
(more accurate).
