TwinTurbo.NET: Nissan 300ZX forum - I mean hooking up the fuel lines before installing the rail?
Subject I mean hooking up the fuel lines before installing the rail?
Posted by LivinTheDream on November 21, 2014 at 12:49 PM
  This message has been viewed 519 times.
In Reply To No.The leak test is before the install on the engine >> posted by ZUL8TR on November 21, 2014 at 02:23 AM
Message This way the rail is pressurized with fuel but you can still check for leaks because its not installed. This way you can even guarantee they are all spraying. Turning the CAS without the injectors plugged in will provide just under 50psi. This should be enough to see any leaks. Yes?
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
