TwinTurbo.NET: Nissan 300ZX forum - would pressurizing the rail with fuel be just as good??? (n/m)
LivinTheDream
on November 20, 2014 at 6:40 AM
Air pressure test the injectors on the fuel rail B4 >>>
posted by ZUL8TR
on November 17, 2014 at 06:32 AM
Injector Replacement Help
Z32CheekiBreeki
14:27:09 11/13/14
The plastic caps on the old injectors?
-Grimm-
15:00:50 11/13/14
Should have addressed more in that post
-Grimm-
15:02:37 11/13/14
ZUL8TR
06:32:25 11/17/14
When redoing the connectors to the new style >>>
ZUL8TR
06:37:14 11/17/14
would pressurizing the rail with fuel be just as good??? (n/m) -
LivinTheDream
06:40:57 11/20/14
No.The leak test is before the install on the engine >>
ZUL8TR
02:23:55 11/21/14
I mean hooking up the fuel lines before installing the rail?
LivinTheDream
12:49:31 11/21/14
PS: When doing this test have a shut off valve in >>`
ZUL8TR
02:30:01 11/21/14
they should be fine if no mechanical damage seen
itsa300zx
16:04:54 11/13/14
Yeah no damage as far as I can tell
Z32CheekiBreeki
16:47:32 11/13/14
if you don't have access to a sonic cleaner, I would just
itsa300zx
17:12:53 11/13/14
the injectors im trying to get out and re use are new style
Z32CheekiBreeki
17:46:48 11/13/14
Carb cleaner would be fine
-Grimm-
18:10:20 11/13/14
Nearly impossible to get them out without damaging the caps
ZXoltan
16:30:43 11/14/14
Re: Injector Replacement Help
Kvert
17:27:19 11/14/14
Re: Re: Injector Replacement Help
Kvert
17:37:52 11/14/14
Excellent
Z32CheekiBreeki
08:21:28 11/15/14
Forgot to mention
Z32CheekiBreeki
08:25:07 11/15/14
Re: Forgot to mention
Kvert
22:52:15 11/15/14
