TwinTurbo.NET: Nissan 300ZX forum - Since it was running fine until you replaced the amps
Subject Since it was running fine until you replaced the amps
Posted by doug8867 on November 18, 2014 at 6:31 AM
  This message has been viewed 317 times.
In Reply To Stall at idle on built motor posted by Dsouthz32 on November 18, 2014 at 02:30 AM
Message and plugged in the lighter those items would seem like the most obvious to check. Double check you put the correct amps in the fuse panel and unplug the lighter and check the fuses associated with the lighter. Consult the online manual for a schematic.
I've had my house fuses get tripped when there was an extra heater plugged in, in the garage and a lot of lights were on in the house. Devices that heat up draw a lot of energy.
