TwinTurbo.NET: Nissan 300ZX forum - leak down test? whats the fix? (n/m)
LivinTheDream
on November 13, 2014 at 3:42 PM
^Or no compression
posted by -Grimm-
on November 13, 2014 at 09:23 AM
Did injector tests today, I'm quite confused
Matt300ZXT
12:57:35 11/12/14
This makes no sense
spicyZ
13:08:59 11/12/14
Re: This makes no sense
Matt300ZXT
13:19:33 11/12/14
Are you sure you had the right wire for injector 3? (n/m)
spicyZ
14:50:57 11/12/14
Seeing as your issues are on the same bank
FrozTTy
13:43:06 11/12/14
Re: Seeing as your issues are on the same bank
Matt300ZXT
13:54:22 11/12/14
Matt, the ground wire splice is so ez. (n/m)
ttz'in (NorCal)
14:00:52 11/12/14
Re: Matt, the ground wire splice is so ez.
Matt300ZXT
14:50:24 11/12/14
That would put the spark for cyl 3
-Grimm-
14:56:52 11/12/14
thats what im thinking (n/m)
LivinTheDream
15:11:38 11/12/14
Do you have de-electric grease on the connectors?
LivinTheDream
14:52:55 11/12/14
also double check that you are testing the right terminals
LivinTheDream
15:07:27 11/12/14
Re: also double check that you are testing the right terminals
Matt300ZXT
15:14:38 11/12/14
Re: Re: also double check that you are testing the right terminals
Matt300ZXT
15:59:26 11/12/14
I dont know how to test it either. clean it up and
LivinTheDream
18:18:29 11/12/14
Bypass the subharness connectors
-Grimm-
09:22:49 11/13/14
wiring is so fun:
LivinTheDream
17:47:42 11/12/14
Re: wiring is so fun:
Matt300ZXT
18:05:25 11/12/14
U'll get it. Seems like a pain but get some rest, place your
LivinTheDream
18:27:45 11/12/14
lastly pull which ever coil pack is not adjusting idle
LivinTheDream
18:48:43 11/12/14
^Or no compression
-Grimm-
09:23:57 11/13/14
leak down test? whats the fix? (n/m) -
LivinTheDream
15:42:53 11/13/14
Leakdown or Bore scope
-Grimm-
18:11:45 11/13/14
Ensure that the injector connector isn't loose. I had a
ZaXxon
04:41:34 11/14/14
