TwinTurbo.NET: Nissan 300ZX forum - Injector Replacement Help
Subject Injector Replacement Help
Posted by Z32CheekiBreeki on November 13, 2014 at 2:27 PM
  This message has been viewed 597 times.
Message Hello all
So I'm in the process of converting my old style injectors to new style ones in my NA
I've got a set of new style used injectors that I'm removing from their fuel rails
I've gotten three out by placing the the rails upside down in a vice, putting a 7mm socket over the pintle cap and giving it a few taps with a hammer
Doing so destroyed the plastic caps, however I'm under the impression that they can be replaced (most of them were broken anyways)
What I want to know is, did I harm the injectors in any way? Beyond the broken plastic caps they look fine, I just want to be sure this is okay before doing the rest.
Also, I'm going with the Z1 conversion kit plus the needed o-rings. Besides a plenum gasket, are there any other parts I absolutely NEED to do this job? And apart from that what are some maintenance items to take care of while I'm in there?
I know of the tb coolant bypass but I'm trying to get some more info about that as most everything I've read seems to be for TT models.
Thanks for reading
