TwinTurbo.NET: Nissan 300ZX forum - Not the knock sensor, and doubt it's the connector.
Subject Not the knock sensor, and doubt it's the connector.
Posted by ttz'in (NorCal) on November 11, 2014 at 10:38 PM
  This message has been viewed 500 times.
In Reply To Re: Re: Re: Injector failure posted by Matt300ZXT on November 11, 2014 at 07:55 PM
Message Doesn't sound like you let a lot of corrosion build up, which is generally cause of connector problems.
Had exactly same issue, even with new EFI harness ! Intermittent dead cylinder (#3). Code 34 then 55, over and over.
Thought about, it and figured since ground signal is sent to all 6 in micro time I would test by running jumper ground wire.
Bingo ! Idle was perfect. #3 coil pack disconnect affected idle same as other 5.
Drove the Z for a few weeks with the splice. Ran fine. Downside over time would be stress placed on ECU driver that sends ground signal to both injectors.
In fact, Gary (DVDBURN) currently has ECU for driver repair.
