TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Injector failure
Subject Re: Re: Injector failure
Posted by ttz'in (NorCal) on November 11, 2014 at 5:57 PM
  This message has been viewed 506 times.
In Reply To Re: Injector failure posted by Matt300ZXT on November 11, 2014 at 04:56 PM
Message Switch coil pack with another cylinder. If problem follows coil pack switch, there's your answer.
If not, check continuity from #1 FI connector ground wire to ECU blue connector pin (color coded). If continuity exists wire is good.
Probably weak/ bad ECU driver. Now knowing which is ground wire from above continuity test. Splice,or just bare the wire
(as in temporary !!), and attach small alligator clip jumper wire from #1 ground wire before connector to easiest adjacent cylinder FI ground wire before connector,probably #2 or 4.
Plug both FI connectors back in. If problem solved, ECU driver.
