TwinTurbo.NET: Nissan 300ZX forum - If there is any the reroute wont remove it. the re route
Subject If there is any the reroute wont remove it. the re route
Posted by LivinTheDream on November 10, 2014 at 7:25 PM
  This message has been viewed 429 times.
In Reply To Does Woody's re-route reduce the oil mist problem? posted by flashstar on November 10, 2014 at 07:06 PM
Message Enables you to keep the pcv valves without getting actual oil in the intake. As for venting to air this would eliminate the mist but you cannot do that on our cars. The only air that can vent from our engines is from the end of the exhaust pipes and the only air that is allowed to enter is from the air filter. Your only choice is an inline catch can.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
