TwinTurbo.NET: Nissan 300ZX forum - not on a turbo. when the plenum is under boost the crank
Subject not on a turbo. when the plenum is under boost the crank
Posted by LivinTheDream on November 10, 2014 at 7:15 PM
  This message has been viewed 424 times.
In Reply To Then would it be possible to connect intake VC hoses posted by ttz'in (NorCal) on November 10, 2014 at 03:31 PM
Message Case would have no where to vent as the pcv valves will be closed. This is why u have the intake valve covers routed to the turn inlet pipe so there is always a suction on the crank case. With an NA the only time the pcv valve would be closed is when there is a back fire or what ever Grimm talked about.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
